Mil T
I'd be interested in sourcing black bolts. I'd be curious on the bolt size too.
Ditto on the black bolts. Let me know if you find them.
Mil T
Everything is perfect on the bolts, except they are too long! Maybe I'll fill the extra space with an extra washer?
I wonder where Method sources their bolts?
You can always grind or cut the extra length off of the bolt.
Has anyone tried Fastenal?
The shortest Fastenal has is 10mm. Looks like I'm grinding them down.
Been researching this for 2 days and spoke to 2 different metric bolt manufacturers and they told me I will not be able to find any hex bolts shorter than 10mm. They told no one needs them in smaller sizes and that the tooling to make short bolts are very expensive.
I did however find black nylon bolts. I may just go with these as they don't rust and that they would be lighter.
And good luck grinding down 80 bolts.![]()
Well, where did you find the black nylon bolts....do tell.
here you go >> Nylon 6/6 Hex Bolt, Metric, Hex Head, Metric Threads, M8-1.25 Thread Size, 6mm Length, Fully Threaded, Made In US, Pack Of 100: Amazon.com: Industrial & Scientific
pic is all wrong (too long) but this size should fit. I think the pic is generic.
