Husky Wheel Well Liner Install
SMIKE
Riverside CA
Got my wheel well liners installed today.
Pretty easy, about 10 min per side and you only need a ratchet with 7mm and 10mm sockets.
They can be ordered here for $129.99. Placed the order Wed and they showed up on Sunday.
Before:
Remove the seven screws holding the fender on (7mm socket)
SMIKE
SMIKE
Riverside CA
Next insert the fender liner into the wheel well. The cutout goes behind the shock. It will take a bit of massaging but goes in pretty easy.
After that you will want to slide the front/outer edge between the body and the stock plastic fender that you unbolted. Work your way around until it is completely inserted.
Then take the 10mm bolts provided and adjust the fender liner until the holes line up with the clips that you put on the body seams.
jjws1968
Michigan
Should have just spent a few more bucks and had them professionally line-x’d. Much cleaner and long lasting if u can find a guy that cares to do it. I could not be happier.
4DPWR
L0R1Y0
Looks great. I have tried to order them but it appears they will not ship to Canada. GRRRRRR
Swacer_2
PA
In the installation post that you were replying to, I was a little curious how the husky liner didn't seem to cover the painted area at the bottom corners of the fender. I was looking at your photos, and it looks like your line-x person didn't coat that area either (the horizontal area at the very bottom of the fender. Is that true?
