Husky Mud Flaps
NASSTY
ME
Any pics of it if you don’t mind ?
With the mud flaps not hanging as low they don't stop as much crap from slinging down the sides of the truck. So I cut some pieces off an old dump truck mud flap and blocked off the front holes on the running boards.
Dakotablues
Michigan
Did you just cement that under there? What'd you use? This makes a ton of sense to me - good idea for sure.
NASSTY
ME
No, but I probably should because I lost a couple last winter and had to make some more. I made a cardboard template and cut them to fit tight. The new ones fit tighter than the first 2 that I lost.
amREADY
Victoria, BC
Damn. Thought I was brilliant to come up with the rubber blocker under the front holes of the running board. Always someone smarter and faster.
At full articulation, the back husky mudflap touches. I'm not overly keen on the look, but they look fairly stock and not too lame.
MW6Ox19gBCH-M2CVELpnAlA4UYwsYvHMFT5Um_aVeJDTBKB3zzZw7WzExB5pDYss43mnz2ABVfSKMtGZS3U6Ftpul-XZiITxfKZE5T_MJdEzqxk8ka-4PirdwfycXnm2PRvknpwgVh-YDOxJL6Wh4xaDmMqek-kdjpk0BB0pu5A1SJl8lGJRpn3GpGZhFAAbM4zxeWjdei1BkfBwfuZjZvahtzHaVUFB1QBK-B0II91mNsGjNtcr3nQE5nSe3fuEyvgPXGYYaPirNEKiyJJHX-hB4PlpoO9u0DlOvH2utfs-fTuAD5Pd1JUuMECFxsbPFkK7_XhtNuTSKGmxYpd5ZXrz9J1on8KyqYtRKisakkAZb90NZEqmHFNhy2elcE0aletjfR9WjbYUjuTB8Pn7pNvAO_T5e0-uZ-EZRVlDXzBCIs4uo6rEQ3vGa9d5xd22T9ILdvmb67NwrlHd3yY15dxO5rcvqBufz5JjjREQjkwLMGVEb8V0uvJF_vmWKsIbteBu6B4fFerNIvThfmZUcCx-yzHWtftv6jNThi7QitltBnCZ7jAuIVEH0MI_lv3Nd1vED9jjRtb4dnodp43thznU9w0RPk4X_lEul27dqOqMi8zvtS70ObafFRjhPuGygvrYH0BxWQtX1S75htV9u_fJdHMlAmYQztHC9HO83yR9TRfs2E-kVCA=w1283-h962-no
I think covering the first sets of running board holes will make a huge difference to how much crap gets flung up on the outside of the door and against the back 'haunch'. Will see.
Am thinking I would undercoat the running boards, the area beside the running boards and rear wheelwells to reduce the rock noise and gravel blasting of the steel parts which will lead to premature rust. Don't want to do a job on it like I did in my teens. Most of those hoe undercoatings were basically to hold the car together with all the holes and rust. But am thinking some tactical, careful application will help.
Will see how long these back flaps will last. They aren't as much for me, as they are for people following. Might help a bit. And help the back fo the truck a little. Will see.
