How to block phone text message?
boosting1bar
Melbourne, FL
When I paired my phone I chose not to give access to the truck for messaging but allowed phone calls and address book. It worked great, that time. Now every time I get in the truck it requests access to messages and the phone grants it. I've deleted and repaired the phone, but the only thing I've found that works is I have to go into the bluetooth pairing on my phone and uncheck message access every time. Anyone else had this issue or know a more convenient solution?
FordIVTteam
Hey boosting1bar,
I'd like to look into this further. What type of phone are you using and who's the carrier?
Also, which year is your truck, and does it have a touchscreen?
What phone do you have?
You could ask the Ford technical servicer rep on here. I don't remember her name.
Yukon Joe
Run Raptor Run | Great Lakes Raptor Excursions (GLRE)
Hey guys -
Here I am; I take care of all things related to SYNC, MyFord Touch, and navigation. Crystals handles the rest.
Jaclyn
boosting1bar
boosting1bar
Melbourne, FL
Hey boosting1bar,
Jaclyn
Wow I didn't know we had a resource like this here, obviously I'm a n00b lol. My phone is an LG G3 on TMobile (my girlfriend has the same phone on AT&T and the problem persists there). I'm actually an android developer so I'm pretty comfortable sorting out these sorts of errors but short of completely disabling the bluetooth MAP profile in the core of the phone's ROM I can't make this stop happening. The phone is on 4.4.4 and I've tried a couple different custom ROMs as well to see if it were something in LG's configuration of MAP that was making it happen but it has happened across all ROMs.
The truck is a 2014 and yes it has the touchscreen. After doing some googling last night it looks like there was an option in SYNC/MFT at one point to disable MAP but I can't find it there now. Ideally that's what I'd like to do is just disable it in the truck because I actually use MAP with other devices at work.
Other stuff that may help you, I've completely deleted the device from the truck each time I've loaded a new ROM and paired it. I've done a battery disconnect in the truck to reset the radio to assure it wasn't a cached setting. Each time I pair the phone the first prompt I get after confirming the PIN is would I like to allow access to messaging for the truck and regardless of whether I pick Yes or No it still accesses it and I have to go into the BT pairing and manually disconnect it each time, and each time I get back into the truck it automatically connects to messaging without any prompting.
I hope we can sort this out because if I'm honest, the speed and functionality of the infotainment system otherwise is quite impressive and I'd go so far as to say it's the best OEM system I've ever used and better than even some aftermarket gear. I've been very, very surprised and pleased aside from this one small foible.
