Trick.Raptor
The Cracker Raptor
Compared to my previous Jeep Grand Cherokee, Jeep Cherokee and Nissan Titan the ride in the Raptor is night and day. Where the Raptor really shines is off-road, at speed this is where you really notice how great the ride is stock.
There is a difference between great ride and smooth though and I think your expectations are not what the Raptor is made for. In the end, this is a big pig of a truck and there is no hiding that...
It's just the most bad-ass outrageous big pig of a truck you will ever drive
---------- Post added at 05:47 PM ---------- Previous post was at 05:41 PM ----------
How are the tires wearing at that pressure? I ask because my older Jeeps ran BFG KO's at the recommended pressure and they wore evenly over the time I had them. My Titan at 35PSI (recommended) wore the centers out and it was not noticeable until 30,000+ miles but I was able to adjust the pressure and at 50,000 they looked normal again (and quite used!).
At 44PSI the Raptor is riding rough but I have not looked at what others are running and at what point will the tire wear unevenly...
(edit... didn't see the response about PSI until after I asked a question)
That said, at 38PSI and below you will get a pressure warning, correct? Anyone seeing any uneven tire wear at 40PSI?
Sounds to me like you have way too much air in the tires.
Try airing down to 40 psi. I ride 40 in front and 38 in the back.
It's the first thing I did when I received my truck 4 years ago, they had 50 psi in all the tires. The 44 psi. recommended pressure is still to hard for me.
If you don't have a Tune you won't be able to go lower than 40 without the warning light going on.
And a set of Deavers rear springs will diffinetly help with the rear jitters.
