How much sag with Deaver +3
BoostCreep
SoCal
Does anyone know approximately how much weight in the bed it would take to sag a Deaver +3 (non HD) 1”?
2slo4u
Utah
I think a lot depends on how you have the front setup. I have a 2018 with the upgraded fox external bypass resivors which lifts the front a couple of inches. With Deavers +3 non hd, the back will start to sag after adding a second spare and another 100 - 150 lbs of stuff.
Gen1TillDeath
cincinnati
I believe i remember reading anymore than 300lbs. Of constant weight +3 HD’s and up are advised. But keep in mind, with +2,+3, ect…, the arch is the only thing that changes, not the amount of leafs. the HD’s have thicker metal Leafs.
BoostCreep
BoostCreep
SoCal
Yea, I’m level right now with stock leaves, and am torn between +2HD’s or +3SD’s and leaving 1” of rake, and want to know how much I can load the rear before the +3’s are level.
