How long are your spark plugs lasting?
TravisHTX
Houston
I don’t know if I just have bad luck, or maybe I just drive like too much of an A hole. I have had 3 F150 3.5 eco boosts since 2012 (the 3rd being my 2019 Rap). Every one of them started idling a little rough around 30k - 40k miles.
Replacing the plugs always helped. Usually around that same time frame, I have a coil go bad as well…
On the Rap, replaced the plugs at 35k, smoothed things out a good bit. Just replaced the first coil at about 39k, and think I have another that will probably be throwing a check engine light within a few K miles. I might just replace all the dam coils in 1 go.
And I don’t even have a tune.
Full-race Geoff appears to have a good recommendation for plugs I will likely try next, post 3 in the link below.
1BAD454SSv2
HELL I ZONA
Every 10K miles , I have it down to a 20 min job of actual wrenching , another 15 min prepping and gapping plugs and tools . LTR7BHX one step colder .026 gap . E50 goose tune tune.
SCAR911
SCAR911
Arizona
Changed plugs and all is fine. Guess I just go through them quick. They were barely discolored.
Sunchild714
Las Vegas
Tuned trucks are running:​
Ford Performance M-12405-35T​
.026-.028​
I know. I'm running NGK's gapped at .026. wondering if he's running the same. My truck started throwing this code at about 7k miles on the NGK'S. I'm gonna change them but heard the Ford Performance might be better. Maybe?
pcs
milky way
barely discolored plugs after use might not be a good thing. clean plugs could be a sign of an engine running lean/hot or coolant getting into cylinder and steam cleaning the plugs.
ThePaintPirate
SE Iowa
Just replaced mine with SP-594 plugs this weekend at 76k, Cobb off the shelf tune. Probably didn't need them but I don't know the last time they were replaced.
