How is this piece removed?
Zev
Florida
Can anyone tell me how I go about changing out this trim piece, looks like it’s held in with one rivet. Is there a special tool to extract rivets?
Muchmore
Kansas City
Unless it's changed, "They use an ordinary rivet with a silicone washer installed to seal out water" They are riveted in and need rear glass removed. Just grind the head off the rivet the back will pull off once you get the trim out.
Z
Zev
Florida
So it’s a bit of pain in the *** then, rear glass has to be pulled.
Muchmore
Kansas City
Why do you wanna remove it?
Also….not the best design & I don’t even get why they exist, other than to get pine needles & crud stuck under them & eventually start pointing upward & looking odd
Between the Badger-t1ts and pine needles sticking up you have a gift for the visual :)
K223
Florida
It’s odd and it’s ugly. Every time i wash the truck I notice it and try to forget it exists. A few years back and I would be doing a redesign on it. You can probably just silicon it down flat.
CoronaRaptor
CANADA
Just put a piece of Black Gorilla tape over it! Nobody will notice, lol
