How get wires from door to cabin?
no1
Has anyone done wiring from door to cabin? would like to get ideas how to do that. Found out today that there is connector plug from door to cabin.
My goal is to get sideview camera wires to cabin. If there some good way to do it or someone have done for example speaker wires would like to know how you did it. Pictures would be great.
Thank you
-J
no1
no1
thank you, sir. Should have known better that there is thread ;) Of course.
i had a lot of wires to run so i pulled off my door, drilled 2 holes and ran a second rubber boot
no1
no1
rubber boot
You have part number for those rubber boots? Wont get those here, so would like to order two of those, each side. Then i don't have to cut RCA jacks and could run more wires for later instal of upgraded audio.
Also going to send PM for you, soon ---^--- since your Guru here
Thank you
-Jan
Thank you
-Jan
unfortunately there is no part number on the rubber boots. the boots only come with a complete wire harness. i checked with several dealers of different manufacturers and they all told me i had to buy the whole harness for thousands of dollars. i ended up going to a junkyard and searching a lot of vehicles to find the boot that i wanted. $7 is a whole lot better than $2000. i think it came off a nissan. but it has to be round. that way i was able to use my hole saw to make a clean hole. the oval ones will take some time to cut out correctly.
no1
no1
Well then it's of to junk yard :) Thank you. I just have to try find one or two somewhere. Going Wednesday local US parts dealer that have old parts maybe i found those there.
Thanks
theres a junkyard called pick and pull here. you go in with your own tools and take what you want off thr vehicles on the lot. i dont know how it works in your area, but i pulled the harness loose, and cut all the wires in the way. 15 minutes and i was out of there (after searching 1 hour for the right harness boot)
no1
no1
They do all the work here and just charge more of doing that ;)
-Jan
