How Difficult Is It...
Dunnbrother
Stockholm, New Jersey
...to install a catback without a lift? I'm assuming the real tough part would be getting the stock exhaust off with such small clearance but was thinking it wouldn't be that difficult if it was jacked up a decent amount. Let me know if I'm smokin dope.
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
Its not impossible, but its not going to be fun at all. The tubes that go up and over the rear axles will be a real pain. I have my exhaust exiting before the rear tire. I just took it off to clean up the tip with a grinder. Its not fun.
RatedSVT
Sleepy Hollow,IL
Well I had mine done with a lift. Taking it off is rather easy with the way the clamps are on their. Now putting the new cat-back on was alil bit of a pain cause you have to wiggle the connections together and hopefully the piping fits with each other like it should. My Borla stinger cat-back needed alil bit more of a bigger opening where the tail pipes met the muffler.
DynoDynge
Zavalla, TX
I did mine in about an hour w/o a lift.
Simply cut the tubes in front of the rear axle & separate.
Pulls out very easy
johnlocal3
Yeah I did mine without a lift also its not that hard. Drop the spare tire before you start it will give you more room to play. Now I just got done installing my Stainless Works headers without a lift.... now that was a workout..
AngryBird
Near Santa Fe, NM
It wasn't hard to do without a lift. I jacked up the rear of the truck at one point to increase the room between the rear axle and the bed I was able to twist off my factory exhaust without too much trouble.
