BigJ
- Joined
- Aug 5, 2010
- Posts
- 5,448
- Reaction score
- 1,561
No problem PH. Here's a quick pic; it aint pretty but it gets the job done just fine.
I connected both sides up to upfitter 3. If the mess coming thru the firewall isn't making sense to ya, make sure you read this thread:
http://www.fordraptorforum.com/f12/upfitter-aux-switch-wiring-explained-5418/
this one too:
http://www.fordraptorforum.com/f12/pass-thru-wires-upfitter-switches-explained-video-6501/
The ground you can see on the left hand side there of the pic. From the driver's side I pulled both the power lead and ground wire thru and under the plastic grade/shroud, so that I only needed one grounding spot. And as you can see, that's a factory ground spot that I'm using. I'm going to eventually replace it with a ground block to clean up that mess I created, but for now it works fine.
Hope that helps!
this one too:
Hope that helps!
