High mileage owners please check in
wjoutlaw
San Antonio, Texas
I am using my Raptor as a daily driver. As soon as I finish the BSN program, I'll be getting it out more and do what they were built for. Just right now, school and working full-time plus mandatory overtime 8hrs week sucked all my free time into oblivion. I drive roughly 10,000-12,000miles a year as it is.
lukelindeman
TN
Came across this thread and figured I would tell what maintenance I have had done. It is a 2010 with the 5.4 L and 130,000 miles. So far I have replaced...
Passenger temperature door actuator at 50,000 miles for $170
Blower motor resistor and HVAC door at 95,000 miles for $600
Radiator/hoses/serpentine belt at 105,000 miles for $1,200
Spark plugs at 115,000 miles for $500
Fuse relocation kit at 116,000 for $600
Replaced the alternator at 128,000 for $500
Other than those issues it has been very reliable. I am needing some new or rebuilt shocks badly as they are still the original ones, but I am on a tight budget currently so trying to find some used ones for cheap. Does anyone have some suggestions for preventative maintenance that I should get done?
mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
What fuse relocation did you pay $600 for? Fuel pump fuse 27 kit is $20 bucks on Amazon and an hour work for a novice to do.
lukelindeman
TN
Yeah I'm aware of that now. Truck would not start and was the third time that it happened and did not know what the issue was, so I took it to the stealership and that's what they charged. Should have done some more research before.
badm0t0rfinger
Rocket Man
The Beach
I got mine done at the dealership and even then it cost parts and labor. 120 bucks I think. You probably got charged diagnostics plus parts and labor.
CoronaRaptor
CANADA
Change all your fluids, both diffs, transfer case, except your transmission unless its been done already as I'm a firm believer that nobody should touch that unless its removing the drain pan and changing the filter and then topping back up, don't do the "flush" the stealerships advertise.
