Hi beam relay trigger wire?
Speeddeacon
NC
I'm am going to add some relays for my aux lights. For the ones I want to trigger off of high beams I need to know the best location to tap into the high beam wire. I know some of you have done this and was hoping someone could point me to the right wire with the most convenient access. TIA.
goblues38
STL
should be able to find it right off one of the front head light. DO it on the battery side, so you can fuse your relay there.
Speeddeacon
Speeddeacon
NC
Yeah, there is a harness with all the wires going into the headlight, just not sure which one the high beam is. May be a better place to access it upstream perhaps.
4x4TruckLEDs.com
So you have his relay kit with the high beam trigger? If so you should have his instructions which point out which wires to use, right? I don't have the instructions readily available or i'd tell you which wire he uses.
Speeddeacon
Speeddeacon
NC
No. I built my own relay box but bought his mount. The wire would be really helpful if you get a chance.
4x4TruckLEDs.com
It's at the shop (I hope anyway, since I have to tap my hi-beam in as well). I know it's online somewhere. His site has smaller photos of it that I found.
Speeddeacon
Speeddeacon
NC
Looks like it’s the gray with orange stripe.
rsbug
N Texas
volt meter would verify, I’m getting ready to run the trigger wire off of my SP9100 setup. I’ll tap into the hi-beam and give it a try and report back. Hopefully by this Sunday
