Help-passenger rear window won’t go back up
JasonSTL
St. Louis, MO
Got in the truck and rolled the windows down because it said 109 degrees. Rear window won’t go up. It’s hot as shit and the wind buffeting sound is terrible. Any reset tricks? I can hear the click when I hit the switch.
Antho
The other rear window work?
Assuming the switch on rear door doesn’t work?
NJ2020
Twin Cities
I have the same issue, it’s still not fixed as part is not available.
J
JasonSTL
St. Louis, MO
Well damn. Did they give you a loaner to drive it at least get the window up for you? The other windows all work fine and neither switch gets the passenger rear to move.
NJ2020
Twin Cities
No, loaners are weeks out. I drove with my window down for 2 weeks before I went crazy.
Seems to becoming a common problem at least on the regular F-150 group, always looks to be the passenger rear and dealers always misdiagnose the first time and try to order a motor or regulator first.
J
JasonSTL
St. Louis, MO
2 weeks! I about went crazy on a 20 mile ride home. I’m stopping by the dealer tomorrow and hopefully they can either get the window up or get me a loaner or rental.
Antho
Well, If you want to pull the master switch i can give you the diagrams. Sounds like the Passenger rear Left is stuck on the "down" position based on @NJ2020. Should be able to pull that pin and roll the window up until the new switch comes in. Looks like a yellow wire @ pin17
