Bump to see if anyone has an answer on mounting relays.
Also wondering if someone has identified the best place to access the high beam wiring to trigger a relay.
Thanks!
I just logged in to update this thread. I installed my relays today. Everything went great and works perfect. Now if my Aux 1&2 switches are on and I flash or turn on my high beams, my light bars turn on. This is so convenient to be able to turn on/off your off road lights this way! And of course you can leave them off, too. Just don't power them w/the aux switches.
So here's the info: The easiest tap I found was on the drivers side light harness where it plugs into the headlight assembly. It's easy to get to by just taking off the intake that hooks to the top of the front grill. Just two little plastic clips and an 8mm screw that holds the intake to the air filter housing. Once that's removed it's easy to access and unclip the harness from the front light assembly. And there's plenty of room to work. I thought the passenger side light harness was not easy to reach because of the battery and washer fluid reservoir.
Using a multi-meter I determined the gray w/orange stripe wire is the high beam hot wire (the one I'm pointing to with the probe tip - see pics). I tied into that line w/an 8 foot length 16 gauge wire (but I think 18 gauge would have been better- 16 was a bit too thick- but it worked). I ran the wire along the top of the grill (under that plastic cover that you can remove by removing all those plastic clips). This single wire is being used to trigger both of my relays.
I tied in all the wires for power and grounds, tested, then thoroughly wrapped all the crimps in electrical tape. The two relays are sitting on the plastic tray by the battery (see pics).
Hope this helps anyone considering doing this. It really was a very easy project that adds a lot of convenience. Have fun!
