Help! No power on Upfitter 1 and 2, fuses are good
MAMiller44
Tampa, FL
It's a 2019....I'm testing the ones that the manual has...12 and 65 I think...both are 15A split M fuses and there's only 1 or maybe 2 other 15A M fuses in there.
When I pull those fuses and test them with the upfitter flipped on I have voltage there and it goes away when I turn off the upfitter.
I'm totally baffled....unless there's an open in the wire from the bottom of the fuse panel to the top where the bundle ends are...I guess I should check that but I don't know if there's anything else in between or if it's just a wire.
All other upfitters are good to go still...so it's not getting worse! :)
Sounds like they’re not properly grounded. Where did you ground to?
CoronaRaptor
CANADA
I think you are checking the wrong fuses. Take a look below and double check if this is for your truck, it should be. 12 and 15 are for 1 and 2 upfitters according to this chart. You also need to "ohm" out each fuse to make sure it is good, while it is in your hand, not in the truck.
Assignment of the fuses in the Power distribution box (2018, 2019, 2020)
Amp Rating Protected Components
1 25A Horn.
2 50A Electric fan 1.
3 30 A Windshield wiper motor.
4 60A Body control module.
5 30 A Starter relay.
6 20A Cigar lighter power point 1.
8 20A Cigar lighter power point 2.
10 5A Rain sensor.
12 15A Upfitter 1 relay (Raptor).
13 10A 4x4 run/start. Adaptive cruise control run/start.
14 - / 15A Not used (spare).
15 7.5A / 15A(Raptor) 2018: Front view camera. Voltage quality module. Headlamp leveling run/start.
2019-2020: Front view camera. Voltage quality module.
Voltage quality module. (15A, Raptor)
16 10A 2018: Powertrain control module.
2019-2020: Powertrain control module. Transmission control module run/start.
17 10A Anti-lock brakes run/start.
18 10A Electric power steering run/start.
19 5A Upfitter 5 relay (Raptor).
20 40A Blower motor.
21 30 A Passenger seat motors.
22 20A Radio amplifier.
23 10A Alt A sensor.
24 30A Trailer brake control module
25 50A Body control module 1.
26 50A Electric fan.
27 30A Driver seat motors/memory module.
28 15 A Heated seat.
29 10A 4x4 solenoid.
30 25 A Trailer tow battery charge.
31 — Not used.
32 10A A/C clutch.
33 — Not used.
34 10A Vehicle power 5 (Diesel).
35 20A Vehicle power 4 (Gas).
35 15 A Vehicle power 4 (Diesel).
36 10A Vehicle power 3.
37 25A Vehicle power 2 (Gas).
37 15 A Vehicle power 2 (Diesel).
38 25A Vehicle power 1 (Gas).
38 20A Vehicle power 1 (Diesel).
39 — Not used.
41 30A Body-control-module voltage-quality-module feed.
43 20A Trailer tow lamps module.
45 — Not used.
46 10A Steering-column lock.
47 50A Powertrain control heater 3 (Diesel).
48 30 A Fuel filter heater.
49 — Not used.
50 30 A Fuel pump.
51 20A Power point 3.
52 50A Powertrain control heater 2 (Diesel).
53 25A Trailer tow park lamps.
54 — Not used.
55 15A Upfitter 2 relay (Raptor).
56 — Not used.
58 5A USB smart charger.
59 — Not used.
60 — Not used.
61 - / 15A 2018: LH HID headlamp (Raptor).
2019-2020: Not used (spare).
62 5A Upfitter 6 relay (Raptor).
63 25A 4x4 2.
64 15A E-locker.
65 — Not used.
66 — Not used.
67 — Not used.
69 — Not used.
70 40A 2018: Electric parking brake.
2019-2020: Anti-lock brake system (ABS) valves. Electric parking brake.
71 25 A 4x4.
72 — Not used.
73 — Not used.
74 10A Trailer tow backup lamps.
75 — Not used.
76 40A Body control module 2.
77 30A Climate controlled seat.
78 10A Spot light module.
79 — Not used.
80 10A Heated windshield wiper. Upfitter 4 relay (Raptor).
81 — Not used.
82 30A Transmission fluid pump.
82 5A Powertrain control module (Diesel).
83 15 A Transmission control module.
84 — Not used.
85 — Not used.
86 — Not used.
87 — Not used.
88 10A Multi-Contour Seats Relay. Upfitter 3 relay (Raptor).
89 30 A Power running boards.
91 — Not used.
93 15A Heated mirrors.
94 15A Rear heated seat module (Raptor, Diesel).
95 - / 15A 2018: RH HID lamp (Raptor).
2019-2020: Not used/Spare.
96 — Not used.
97 40A Electric fan (Raptor).
97 50A Powertrain control heater 1 (Diesel).
98 15A 10R transmission module r/s. 3.3L transmission fluid pump.
99 40A Heated rear window.
100 25A Diesel exhaust fluid (DEF) heater relay (Diesel).
101 25A Electric fan.
102 30 A Power sliding back window.
103 20A Trailer tow stop-turn relay fuse.
104 15A Snowplow switch. Rear heated seats.
105 10A Telescoping mirror.
R02 — Powertrain control module relay.
R05 — Electric fan relay.
MAMiller44
Tampa, FL
1 25A Horn.
10 5A Rain sensor.
31 — Not used.
32 10A A/C clutch.
33 — Not used.
39 — Not used.
45 — Not used.
49 — Not used.
50 30 A Fuel pump.
54 — Not used.
56 — Not used.
59 — Not used.
60 — Not used.
63 25A 4x4 2.
64 15A E-locker.
65 — Not used.
66 — Not used.
67 — Not used.
69 — Not used.
71 25 A 4x4.
72 — Not used.
73 — Not used.
75 — Not used.
79 — Not used.
81 — Not used.
84 — Not used.
85 — Not used.
86 — Not used.
87 — Not used.
91 — Not used.
96 — Not used.
This is not accurate for all Gen 2s. It changes pretty much every year. I have a 2019 as well and like the OP, fuse 12 is for Aux 1 and fuse 55 is for Aux 2.
WV_Raptor
WV_Raptor
West Virginia
Fuses check good in hand. Have to be the correct fuses as I get power on 1 post when I flip the upfitter on (with the fuse pulled to get to the post).
My only thought still is that the wires are toast or whatever is between the fuse box and the wire is toast.
Anyone ever pulled the fuse box out? Looks like a complete and total PITA...
MAMiller44
Tampa, FL
I haven't got anything hooked up to them yet....just testing for power. And for that I tried both the frame ground near the battery and the neg post of the battery.
You’re saying when you tested the lights, the ground wasn’t connected?
WV_Raptor
WV_Raptor
West Virginia
Pretty sure it was. It's all a blur at this point....from excitement to despair.
I'm fairly sure now that it's either the actual relay in the battery junction box or the wire itself.
Managed to get this from a Ford tech, hopefully it helps someone else for something.
So I have power at the "top" of the switching side of Upfitter1 and Upfitter2 relays but don't get anything out the wire....so it's either the non-serviceable relay or the wire....and I'm pretty sure we all know what it's going to be. :(
WV_Raptor
WV_Raptor
West Virginia
When I'm testing for voltage.....Volts....red lead to the left side of the fuse (with fuse removed) and black lead on frame ground/neg battery post...someone in the truck flipping the upfitters. Good switched power for everything in the junction box, good power on the wire bundle except for Aux1 and Aux2
When I'm testing for resistance on the fuse or the wire....Ohms (actually the diode setting so it beeps).
When I checked the wiring last night, I pulled the fuse for Aux5 and checked resistance from the fuse to the end of the wire for Aux5 and had 0 ohms, doing the same thing for Aux1 and I have an open....so it's either the wire or the unserviceable relay (wherever that is)
I suppose I can jump around that section of wiring with some redneck engineering but I'd rather not.
MAMiller44
Tampa, FL
Sounds like you're doing everything right. Last thing I would recommend is check the pass-thru wiring bundle, maybe something was modified at one point in time and those Aux 1/2 wires are the hot ones for some reason? You never know what happened with a previous owner. I guess if I were you I'd try to see what Ford says taking a look at it.
Worst case? Get the fuse box like you saw in my thread, and pull your own new wires directly to the battery/fuses/Aux 1+2 switches. One benefit to that is that you can upsize the wire gauge for 20a fuses and run two LP's off each.
