Hard Roll/Hard Fold/Retractable...which is most secure?
John M BUNMAN
BUNMAN-Adventures, Rescue & Recovery
Las Vegas NV
The Diamondback is the most secure one that I have found. You need more than a pocket knife to get into it. You can get into anything but the d-bag thieves always look for the easiest option A231D8EA-8C39-45C6-90BD-7A9BCA9CE03E.jpeg0EF298C2-29A0-4D92-BA1E-B73A88D6DA2A.jpeg7158FD99-7A7B-4061-BBFE-E1EC7443D1B0.jpegA7E219EE-CB75-4108-9670-86502962ECFC.jpegA385D063-927A-4A0E-A691-CCBE4B7FE916.jpeg
SurfRaptor
Newport Beach CA
I’m pretty interested in the Diamond back. I was thinking a cap (Leer or similar) but I think this will work for me and secure all my stuff. Anything more you can tell us about which model you went with, installation, any regrets? Thanks in advance.
osprey6
South Florida
I have the HD model… it is amazing tough and solid. Install was about 30 minutes. That was because I needed to take me time size I never put a top on before. They say to remove and reinstall it takes 10 minutes and I believe it. I have the butterfly model however you can get with the sides popping up instead. I highly recommend it. Makes the truck look tougher with the top. Add that every stays dry and it seem tough to break in. I actually ordered a retractable top but canceled it and went with the HD.
SurfRaptor
Newport Beach CA
A few questions if you don't mind....
The website says "Auto-opening the tailgate via key fob may not work." Is this true for the raptor?
I am looking at the SE not HD. Did you get any rear sag on the coils installing the HD?
John M BUNMAN
Las Vegas NV
It’s not explained well by them, which is unusual. They are a great company to deal with, just give them a shout they will answer any questions.
TO YOUR QUESTION: What they mean is that if you have the lid secured properly, snug/Tight, the Tailgate won’t just drop open when you press the release button. It Doesn’t interfere with the opening/closing of the Tailgate.
If Im opening the Tailgate, I just twist the locking handle to release the pressure.
As to the Type I chose, The HD model you can put you your Can-Am on the top and strap it down, holds #1200.
I went with the lighter duty, holds #400. You can walk on it, put your tent, chairs etc. Can’t do that with any of the “Pretty” ones, no offense, lol.
Each 1/2 removes in about 2min when you are carrying something Tall, BBQ etc. When you remove either or both halves the only thing remaining is the 6” middle piece that is C-Clamped to the Bed Lips.
RaptorRnr
Northern California
I have a Retrax on my Raptor and a BakFlip on my F-350. The Retrax can be pushed open, even when locked. The BakFlip could probably be pried open using a crowbar fairly easily. I would not recommend either if you're really concerned with break-ins. From What I have seen, @John M is referencing the most secure solution with the Diamondback. That solution, for my needs, isn't ideal due to the way it opens if I need items to stick out like bike tires or wood/plywood.
ThankU45
MA
Having used both, which would you recommend Retrax or BakFlip for a Raptor bed?
