GROUP BUY: SS Braided brake lines
cubiefan101
Illinois
Is this for 2010 too. Heres my rear lines
Im confused........
Will this work?
cbcgeneral
Southeast Pennsylvania
OK I just got off the phone with Crown and this is what I was told.
The 2 lines that do not get swapped out are the 2 rear caliper lines.
The hard line will not separate from the flex but if you want it swapped out you could have someone flare the end with the proper fitting then you could switch over all of the lines.
Pictures below show a 2014 and my 2010 connections.
2014
attachment.php
2010
Drivers side
attachment.php
Passenger side
attachment.php
So guys check these ends.
This is how my 2013 looks also so which set do I need. Man this is the most stressful group buy ever. I think it's actually been giving me grey hair. Lol.
IRONMAN
MICHIGAN
OK, I am confused now (it doesn't take much :ROFLJest::ROFLJest::ROFLJest:) do all 6 lines still get used for the early models? I have a 2011
No your 2011 should be the 6 pcs.
---------- Post added at 02:18 PM ---------- Previous post was at 02:17 PM ----------
Im confused........
Will this work?
You need the 6 pcs as well.
Let me use your pics here to explain better.
Give me a few.
IRONMAN
MICHIGAN
This picture is from a 6pc kit. 2010
This is the Passenger side.
attachment.php
A = hard line coming from junction on rear axle
B = This is the thread that screws into C
C = This is the threaded end of your flex brake line which unscrews from B
D = This is the hook to hold your brake line to the axle.
E = Flex line going to your caliper on the passenger side.
2014 Raptor
attachment.php
Do you guys see the difference?
