grinding in front end
miken
I am getting a metallic grinding noise from my front end when going up an incline. If you let off on the gas the noise goes away. If you give it more gas the grinding gets louder and then there is a loud bang as if the gear is engaging. It happens at all speeds 25mph to 80mph, as long as you are going up an incline. Took it to the dealer 3 times and they cant replicate it. It happens to me almost every drive but not always. any thoughts?
Kamil
Take it to the dealer and drive the mechanic in the car
jabroni619
Pretty much this. I don't even bother taking my vehicles to the dealer if I can't actually show them the problem, because I know what their response is going to be otherwise.
solarwinds
DFW
i get the same noise when i throw a chain into the engine’s moving parts. cant figure it out either.
FTCHMUP
Reno
I was having the same problem. First they put a speed sensor in the front wheel and when that didn't work they replaced the vacuum solenoid that operates the hubs.. good so far.
get it fixed before it destroys your hubs. you probably got water in the solenoid.
wweaver
East TN
That’s what I had do to. Had the head mechanic ride with me. He was not happy that the other mechanics could not figure it out. They replaced the 4wd vacuum system.
