My wife thinks I only have 3 guns
Me too. Two black ones and silver one *sigh*
camburg sells the 2 inch collars. I'm prob going with those in couple weeks. I was quoted $450. for collars with install. I enquired about rpg 1.5 but seems like most people are ditching them and going for little more lift from what I keep reading.
Everything I've been reading says the same about the 1.5 inch not being enough. I know RPG sells an adjustable, so does ICON. The Icon looks to split some of the adjustment, depending on how much "lift" you want between a spring perch and spacer plate depending on level you choose. I'm already at a point I think I need to change my rear springs, either option there I would go with a 1 inch lift over stock with more capacity. I'd like to do something in the front first or at the same time, for that reason I'll probably go with one of the adjustable options in the front. Once the rear springs settle/break in if I'm adjusted all the way up in the front (2.25 inch seems the max on all of them) and still have enough room to go higher, but maintain a slight rake. I could remove the perch and have new springs installed, both seem to lift the front 2.5 inches. (Eibach or Geiser)
