Go Pro Mount - best location?
SoSmoked
changes his exhaust setup more than his underwear
If ur referring to the f150 logo it is there quality just sucks since I didn't convert it for YouTube purposes
BOJANGLES
<span style="color: red;"><b>Administrator</b></sp
Chihuahuan Desert (EPTX)
this sounds cool, but at 6'4" i am not sure i would get a very good camera view from the top of my head.
I'm 6'3" and I think it's gonna work fine. We may have to lower our seats a bit but it should be fine. We'll see when I give it a test run.
....Hey SoSmoked, how tall are you?
obviously everyone is confident the camera is sticking no matter what?? Hood gets hot - but no issues?
I saw SPRSNK's GoPro take a pretty hard whip from thick desert brush when we were on a whooped-out trail we ran at speeds from about 60-80mph.... I was impressed, the thing didn't budge. If you want something even beefier, check out the Fat Gecko mounts with double suction cups like JP7 has on his Drift Cam setup.
might be good opportunity to use the upside down view. . . Sorry could not pass that up.
Upside down view..... Good advice, now the possibilities are endless. :favorites37:
CineSLR
Roaming Shutterbug
New Orleans, LA
If you have tube bumpers a superclamp is definitely the way to go. Then when your done shooting with your gopro, you can throw on an SLR! The other good thing is that these pieces are all modular so if you wanted to add a suction cup later you could easily do that. @ $35 the gopro suction cup will be by far the best deal. The cups we use are almost 3x that but having a suction cup with a pump/line is pretty crucial so you can see quickly and easily if there is a leak. Oh, and bo... I also use the superclamp for my patented "**** cam"... you should try it out. I'll send you an invoice... :D
http://www.bhphotovideo.com/c/product/581220-REG/Manfrotto_155_Double_Ball_Joint.html
Suction Cup...
Matthews 6" Suction Cup With 3/8"-16 Stud 6049/100 B&H
trolls56
Macomb,IL
I was looking at these at best buy today and they only have the helmet cam hero kit. What else do i need to get?
SoSmoked
6 ft 4 inches
BOJANGLES
the usual THUNDER? :favorites37:
Exactly.
All the Hero kits have the same cam, the only differences are the mounts that come with. The helmet hero has a few mounts you can use on the truck, but if you want more, you may wanna google the GoPro Motorsports Hero, which BestBuy doesn't carry (I checked recently). You can also buy any kit and then get the mounts from other kits separately.
6 ft 4 inches
So then, BlackMamba, guys our height would be fine using SoSmoked's method because we are the same size and his videos came out pretty cool.
B
BlackMamba
Houston
FRF could put together a decent basketball team. Glad to know the over 6' crowd can use the head mount. Will definitely try it out.
