GLRE: The Offical 2016 SnoBall thread
Yukon Joe
Trafford, PA
SilentShooter
Siesta Key, FL
RaptorScrew
Oronoco, MN
Wonderful day starting!!!
We leave for Snoball one week from today.
Truck just went in to have new heater put in drivers seat (2nd occurrence) and one the way there had to put into 4wd (city plowed main streets and side streets were not yet touched. Broke through the plow pile.)
Anyway, made left turn and then "CLICK CLICK CLICK CLICK" from left hub.
IWE? I'm having them check it out. We'll see.
I sure as hell hope they get it fixed in time! They know I'm leaving so hopefully they get this done.
SilentShooter
Siesta Key, FL
Mine goes in tomorrow for some prep before the run, They are putting in the Howe power steering system so I will bring along my stock pump that they pull out for a spare should someone need it. (Knock on wood, my truck has never had PS problems but I am being proactive)
Yukon Joe
Trafford, PA
It is an IWE issue for sure. But be careful that the dealer doesn't call it just a vacuum issue. If they do, the vacuum issue and the IWE both need to be fixed.
Calling dibs!
Yukon Joe :baby: :baby:
H O L I D A Y CHEER Event fundraiser
Donate $5 for a chance to win
http://www.fordraptorforum.com/showthread.php?p=944696
RaptorScrew
Oronoco, MN
If they say just vacuum issue what verbiage or reasoning do I give to fix IWE also?
2014RubyRed
Galesburg, IL
That noise you heard was the IWE slipping and grinding itself to pieces. It is damaged if you hear it. If there is a vacuum issue, then it has been wearing the IWE out. The IWE is a metal/plastic part that cannot withstand those issues.
Yukon Joe
Trafford, PA
@RaptorScrew - ^ that is exactly what you tell them. You heard the noise, so you know it is damaged.
