GJ Motorsports 3rd brakelight/chase light install video
4x4TruckLEDs.com
Well Baja Designs does not make the sPOD, although I GUESS technically they DO now, since Bestop bought sPOD and Bestop owns Baja Designs.
Now you can't dim them ALL the way down as eventually the light will turn off, but you will be able to turn it down a bit. Keep in mind you are now adding a lot of extra wiring, as sPOD is a switch panel itself.
Birdnutz
Az
Thanks for all your responses, looking at this and not the controller:
Baja Designs LP-Series Controller Module Harness​
SKU:640168
4x4TruckLEDs.com
SKU:640168
?? That has nothing to do with the GJ Motorsports Kit... that's for LP Series lights and gives you 4 wires on the end...
Birdnutz
Az
Yep, was hoping to tie it in with the harness. The problem is you have to run the power to the stop/turn signal lights for the chase lights to even work……
4x4TruckLEDs.com
The stop/tail/turn harness is honestly a harness most people get so they can strobe their lights. I might have one or two customers that actually use it for its intended purpose.
