GJ Motorsports 3rd Brake Light Wiring
RaptorVette
Corpus Christi, TX
Just got a response from Keith at LVJ Motorsports and the GJ Brake light will NOT work with the cell phone booster because of the frequency. Cell phone boosters run at a much higher frequency.
EastEndAngler
Long Island, NY
Any more details?
The NMO mount's universal. I actually have the BPD dual NMO mount w/ Baja designs lights. In terms antennas , no problem with the Fleet NMO threading on, but I will likely swap for a more traditional antenna with better reception.
@lawndartdesign on instagram has the same setup and has documented his experience.
RaptorVette
Corpus Christi, TX
This is for a cell phone booster. Not for offroading, I don’t need service off road. Building a house in the Texas Hill Country where there isn't currently a signal around our property. Evidently it's not the mount or the antenna, it's the frequency that they operate on.
dnewman9
Lone Tree, CO.
Hi Guys, I bought one of these from GJ and ended up selling the Raptor it was intended for and am trying to get it wired into my Tremor. I grabbed this picture off the internet, my wiring is essentially identical, I have three wires in the big white connector on the upper right, I have my brake lights connected to the red and black there. The Tremor uses the center light for the camera so I have a white and amber outboard on either side.
My question is, can I take the white wire from the white connector and plug it into the open connector terminal on the black box marked in/in-out, or do I need the black box in the lower left? I did not get that box and have no idea what it does? All I am looking for is to make my white outboard light come on with the cargo buttons, and I will wire one of the up fitter switches to it secondarily when needed.
Anyone have a suggestion? @4x4TruckLEDs.com any advice would be appreciated!
ImAllSCREWdUp
PG Co. MD
Purchased one of these from @NateMob and attempted install this weekend. Found very quickly that the oem brake light harness plug is 4 prong and the G-J receiver is is two prong. Do I need an intermediate harness? Am I missing something?
NateMob
SATX
Dang man, sorry you've run into a problem. Which harness did you order to go with it? I saw GJ post (possibly on FB) that they were using taps somewhere in the kit because a certain harness was unobtainium at the moment. Keith at LVJ Motorsports may be your best best for getting sorted quickly, i believe he builds the wiring for these.
4x4TruckLEDs.com
Are you saying you purchased a used brake light from someone? On a Gen2 there is another module that comes with the brake lights. It plugs between the brake light and the factory harness. You need that module also
Members online
96,139
59,972
23UniFordicorn23
