MarkT
- Joined
- Mar 4, 2010
- Posts
- 1,202
- Reaction score
- 26
How much does a 35" General Grabber weigh? (with or without the stock Raptor wheel) Thanks.
Ok I am on the east coast so I don't make many wide open desert runs full of jumps. Our stock tire is roughly a 35 by 12.5 and the General tires are and long with most 37 inch tires are 37 x 12.5 so the tire is a few inches taller. For the problem I can see is at full lock to lock steering input where the suspension is compressed. Also there is the possibly to us the truxxx leveling kit as spacers to get another few inches of lift.I'm betting if you drive the Raptor like it's meant to be driven that the 37's will remove the fender liners for you. You'll probably want to do that before the Raptor does it for you.
I'm not sure it's purely a vertical height issue (I think it'll take more than raising the Raptor UP a couple-three inches). The tires are larger in every direction not just upwards.
I wonder if the 37's will do more than "remove" the fender liners.
78.7 lbHow much does a 35" General Grabber weigh? (with or without the stock Raptor wheel) Thanks.
So its when the truck is turned lock to lock. Removing the inner fender liner will fix this. Correct.78.7 lb
The General 37's are not available in a DOT approved tire as of yet. With a 37" tire you will get rubbing at the rear of the front wheel well when turning in and out of a parking spot with out trimming the plastic.
