GEN3 Forscan
ganooch
Dallas, TX
Since you seem to be the subject matter expert on here do you want to post all the required changes in one message? You said there were a few additional changes needed?
***Back up your modules and use the below at your own risk****
All of the changes below are required. Result in your Setting menu will be Glare Free replacing Auto hi-beams, you won't have both. Also, on the bottom left corner of the dash, you will push the stalk forward to cycle through no indicator, green Auto indicator, and blue hi-beams indicator (hi-beams off, glare-free, normal hi-beams on respectively).
Glare Free Menu (replaces Auto High beam) in APIM:
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
Note: a module reset in FORScan or power cycle is required for the menu to appear.
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
Short bed with scales / ccd or Raptor
734-01-04 xx56 D1
Credit to ROBB1, tonesto7, and Livnitup over at F150gen14.com forum.
jjslat
jjslat
Georgia
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
734-01-04 xx56 D1
Awesome thanks, excited to try it.
Curious, is the "Short bed with Scales" change at the bottom part of glare free lighting or a seperate thing? Sorry if I missed it somewhere but can we enable the Scales stuff on Raptors?
ganooch
Dallas, TX
It is a required change for glare free. There are several different configs for different models. The one I listed is for short-bed with scales and Raptor, which is for you.
LennyMoe
AZ
Hey @ganooch , sorry if this has been covered already, but is there an option to have the amber lights ONLY for daytime running when the lights are in AUTO mode?
taco-13
Long Island, NY
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
734-01-04 xx56 D1
Anyone using this feature. Really interested in trying it out.
