GEN3 Forscan
BCH08
US
Ok, I might be slow on this one but what is the welcome chime called. The one when you get in the truck and push the ignition? Really want to shut that one off. Also wouldn't mind the chime for when you're in gear (not in park) and open the door. Please no flaming on that one
i had a little trouble at first on this one. Then did some more searching and I got it now. I have a 23 Raptor. my steps:
-I already had the driver seatbelt reminder disabled (did that just in the truck, no forscan)
-tried editing the IPC module and it didn't work, but found another thread saying you had to disable more so
-disabled passenger seatbelt reminder
-disabled chime-vehicle running with door open (mine was set to manual transmission, changed to disabled
-then went to IPC 720-01-02 and changed the value stated (mine went from 0 to 2) (I found this from a forscan pdf for 2015-2019 F150's, so confirm the module yourself)
mine also changed some of the letters after doing that, I believe that is normal from the reading I have done.
I haven't driven it yet, but in the garage, when I press the button like I'm going to start it, no do do do / welcome chime.
Spooky
Virginia
Is there a procedure to add the auto tilt side mirrors in reverse? I didn't see it listed on the spreadsheet.
swoop1156
USA
It's somewhere either in this thread or elsewhere in the spreadheet. I recall seeing it and trying, but when I pulled up my DDM/PDM for the driver/passenger side - my numbers didn't go high enough to edit anything... I'll see if I can find it for ya.
ganooch
Dallas, TX
I had the same problem. Called Ford (833)389-0848. Told them I've not received any updates. They did some testing while on the phone in the truck. Confirmed there was an issue and started a case. TSB-22-2404 was the problem. Took it to the dealership and they updated a module and then got all updates. NO CHARGE.
Hope this helps.
I just did this and was told that there are no updates pending so they can't help on their end. We verified the SW level in the truck and they agreed that I am way behind on updates, but there is nothing that they can do. Told me to take it to the dealership and gave me a number for the service department to call if they say they don't know how to manually do the updates. Annoying.
pnwobrigade
WA
Might have missed it posted here but what is the OEM 37PP setting under the BdyCM Module for 37” Circumference in mm? Trying to adjust my tire size going from 35” to 37” and would like to use the OEM value.
MikeJones603
New Hampshire
Can someone please send me the spreadsheet (or link), and also software download instructions? It's been a while..
I have hardware but need to download the software to a new PC. Has anyone download the software on windows 11 yet?
TIA
