GEN3 Forscan
swoop1156
USA
Did the glare-free mod today when the truck got delivered. Never drove it in the dark without the mod. Turned it off through touchscreen on and off a few times down the main but country road. Definitely a huge difference! Thanks to all on the forum for making it possible for my smooth brain to understand.
JoeMoe
My last OTA update was from October of last year. Mine is a 21' I picked up in early September of 2021.
Sorry to get the main topic of this thread off track a bit. Wasn't my intention.
I had the same problem. Called Ford (833)389-0848. Told them I've not received any updates. They did some testing while on the phone in the truck. Confirmed there was an issue and started a case. TSB-22-2404 was the problem. Took it to the dealership and they updated a module and then got all updates. NO CHARGE.
Hope this helps.
Wichadicha
Georgia
Ok, I might be slow on this one but what is the welcome chime called. The one when you get in the truck and push the ignition? Really want to shut that one off. Also wouldn't mind the chime for when you're in gear (not in park) and open the door. Please no flaming on that one
Sparda1123
Orlando, FL
Alright so maybe I missed it but I've read through the thread, searched and went thru trying different values from the sheet with no luck. Anyone have the values for oil temp and trans temp under the gauges at the top of the cluster? I can see it by going to the measurements page but I saw a few folks mention they've got it working at the top without sharing what values they changed to do so.
Chop96
Fredericksburg, VA
Here you go:
Enable digital temps for engine & transmission on 12" digital cluster only IPC 720-07-01 xxxx x**x xx-- E5
I'd love one for oil pressure so there's numbers across all four... anyone have that?
:cheers:
MattR
Has anyone found a Forscan setting to change the amount of time before the alarm for "place hands on wheel" when in cruise control?
I will have my hands on the wheel and it still alarms, over and over, to the point that I usually don't use the lane assist
Bubbasuwannee
Angier, NC
That's actually a great idea. That gets so annoying on long trips.
Antho
No. Its not configurable. If it was, everyone would just turn it off. LOL
