GEN3 Forscan
RaptorAU
Alabama
Are you talking about when the lights are on, or when they are off? If AUTO is selected and it is daytime, the white or green "A" will not be present. It is only illuminated on the dashboard when the lights are physically on to inform you that they are on. Oddly enough, in our Cayenne, the A is white and it is always on the dashboard, and it turns green when the lights are on.
I'll take a short clip here in a few hours but let's say I pull in the garage, auto lights kick on, no A is present in the lower left it will only show green headlight symbol and fog lights. I wish I knew what the value was for that symbol or where it is to even check.
swoop1156
USA
Sounds like normal operation to me if that's what it's doing. Or is that what you want it to do?
RaptorAU
Alabama
I’m just wondering why it went away if no one else’s did. I’ve attached some photos. Pulled into the garage with auto on.
swoop1156
USA
Ha! Oh wow. I get it, now. That's kinda odd... I think you're the first with this issue.
RaptorAU
Alabama
Took about 10 seconds give or take for the auto’s to kick on once pulling in. I’m assuming that’s normal. I’m curious if it’s a BCM issue? Wondering if I should revert to as built to test it. I wouldn’t thought the instrument cluster but no.
RogueClimber
Captain Rob
Marina del Rey CA
Have you cycled the stalk (which IIR affects the mode)?
swoop1156
USA
The stalk? Is that a module? Excuse my dumbassness here
The turn signal stick that comes out of the steering column. Instead of pulling backwards to flash your brights, push it forward. It'll cycle between "A", low beams, then high beams. You could be on low beams only, which would negate the "A" showing up and thus, not allowing GF to function.
RaptorAU
Alabama
Ah! Okay, tested it and when pulling towards me it flashes to high beams, pushing it fowards just turns on high beams. No other points on it. Auto still didn't show up. Surely this isn't a BCM issue like I stated but it's like it started after that.
