[Gen2] New Engine Price? Follow up on Blown Engine...
U
unashamed7
SLO, CA
I just replaced my motor in the fall here in Gilbert AZ with a brand new Ecoboost for $21k with a 3 year unlimited mileage warranty. My truck had 93,000 miles (it’s a 2018) and I change the oil at 5000 miles regularly. Major bummer. I looked into several 5.0 or 7.3 options and they were at least double and sometimes triple what I paid to repair it.
Thanks @roostinyfz, this aligns with what I’m seeing across my quotes. Dang, I was thinking the same thing for bigger engine - labor costs must’ve been a lot more to retrofit I guess?
U
unashamed7
SLO, CA
This is a little off subject, but it ties in with the former owner saying he performed regular maintenance. When I do self-maintenance, I go to carfax and record the maintenance, along with uploading my receipts for parts. It goes a long way in assuring the next buyer that the maintenance was actually performed. When I sold my 2015 F150 3.5eb with 210k, I passed my binder with all of the repair & maintenance receipts to him, as well. For my Raptor, I'm also doing a blackstone-labs oil report every other oil change. I do full synthetic oil changes every 5k. BTW, the reports confirm the oil is still in healthy ranges, so I feel confident that I don't need to do them more frequently.
@Rickmeister 100%, I heard someone else mention carfax too and I’m realizing that he likely didn’t do that regular of oil changes unfortunately. But it still made it to 172 surprisingly.
I’m a big fan of your maintenance methods, thanks for sharing. Glad to hear your 3.5eb lasted so long! Black stone labs is a great idea thanks for the tips.
roostinyfz
What I learned is a big expense of a 5.0 or a 7.3 liter swap is even though the transmission will work with it, the housing locates and mounts the transmission in a new different location than the ecoboost. This requires a new transmission in the swap and a lot of added expense.
Badgertits
Ma
If Ford was REALLY confident in that coyote it’d be in the Ford GT….but it ain’t.
Tomkirkland4
Send me a DM with your phone number. I just went through this and had to replace my engine with a long block. Happy to provide all my receipts from Ford.
EricM
OHIO
Can't be more than 4.0L and run boost in the class th car was developed for.
5.5L was the max N/A and Ford wasn't going to make a 5.5L V8 just for the GT.
The Coyote is deriviative of the 4.6L mod motor from 1996. The most reliable V8 in the history of the planet.
Ford has made the modular V8 engine much less reliable as they've jacked the power from 215HP to 700+ over the last 30 years, but at the same power level - the Coyote block is stiffer and the cylinder pressures are lower than the Cyclone derived 3.5L EB engines.
Keeping cylinder pressures low and having a block stiff enough to actually hold the crank bearings in place is what matters when it comes to keeping a high HP engine intact. The V6 loses to the V8 on both.
Why didn't Ford just turn up the boost some more on the V6 for the Raptor R if it's that easy?
