Gen 3 Raptor 37 Geiser Rear coils install + pics
BSRKNU-big scotty
san diego
Super easy, torque specs are 1 1/2 grunts
Saw a forum once all kinds of folks asking about the torque on their lug nuts, 10th or so guy down says "You should torque em with the T wrench in the trunk you're going to have to take em off with when you get a flat" Too logical for some, couple hard grunts is pretty F___N tight enough for me !! Good post but can you get me a nice 4 link set up for my 2013 !!??
J
j-man
los angeles
Did the axle shift to the right or left a little bit? Is one tire moved out on on side and in on the other? This usually happens with a panhard bar set up, hence adjustable panhard bar used when a vehicle is lowered/lifted to bring the axle back to center….
Not that i noticed, it still tracks straight, no funny bounce or shifting left/right when i hit bumps, but i havnt taken it at speed in the dirt or rocks yet. I remember on a 99 4runner i owned after i lifted it, it was a pain adjusting the panhard bar to get it just right, bu so far the Raptor seems fine. But now you,ve made me wanna go measure things so ill check
RobBob
DALLAS
I purchased a set for the rear a few days ago… wondering about the shift one side or the other that you refer to. I can check prior to installing and after. Haven’t received them yet - but, where is going to be a good reference point to measure from to offer this information back to the forum? Is there a common place to measure from for this check?
BoostCreep
SoCal
I think the G3 rear is designed with so much travel that you’re not going to see too much deviation of the axle laterally, especially around the ride height. Full droop vs full compression there will certainly be a change, but lifting it a couple inches I bet would change it less than 1/4”
lawraptor
Northern Nevada
Great post. With the shell on you're at about 3 inches rake? I've got a Leer XR going on in a few weeks on my 3rd gen, and worried about the front end being higher. Don't the Leers only weight about 185-200?
J
j-man
los angeles
Yea the leer is right around that, after a couple weeks its still about 3” rake
