GEN 3 Official Aftermarket Wheels Thread
LennyMoe
AZ
Hey @Pacific Wheel what would 17x8.5 +25 look like? If I'm understanding correctly, they would be about .350" out from stock, yeah? Do you know how much of a difference adding perch collars would make?
I'm looking for new wheels for my '21, but I'm not planning to raise the front until I need new tires. I'm kind of torn on the amount of "poke" that I want (definitely no more than +0). I don't want to be in a position where if I raise the front end down the line, I feel like I need new wheels because the collars pulled them in more than stock.
Any thoughts or advice would be great! Thanks!
QCRappy
Charlotte, NC
perch collars dont change the wheels at all - pick a wheel you like and go with it. The perch only changes the front height. Only reason for perch/collars is it you want to level or wanting to squeeze 37's that are not BFG k02's.
catinthehat85
Socal
Hey @LennyMoe @Qcfx2 is correct. It really just comes down to looks. Below is a pic of a +00. The +25 is very close to a stock fitment.
Thanks for the info! @Pacific Wheel Do you know if these +00 methods will have any issues tucking under the fender flares at full compression? I have a 37pp on order and didn’t want to add perch collars. I’ll be using the stock ko2’s. I don’t mind a little trimming to clear for turning angles, but not tearing up fenders during landings is important to me.
Pacific Wheel
Pacific Wheel
Reno, NV
I'm not certain. I haven't had anyone say anything. Plenty of orders for them but now sure what they're doing with their trucks. I might stick with a +25 if you plan some full compression action.
pnwobrigade
WA
Do you happen to have a similar shot with +25, I know it's basically only 10mm more than OEM wheels outward. I'm looking at the Method 315 in +0 but also concerned with possible rubbing under full compression or actually being used off-road. I've read +0 can be a problem some on Gen2 but the Gen3 has more room so haven't found a clear answer on that.
