GEN 3 Official Aftermarket Wheels Thread
Raptorbert
Hampshire, IL
Perfect would be stock suspension. It is what engineers spent countless hours and years developing and perfecting.
The perfectionist in me says leave it alone. Only thing that needed improvement to me was a lighter and more aesthetically appealing wheel/tire combo.
I’ve read a bunch stating that depending on offset you could have none or some or much rubbing. I figured index would be better than the level up bump stop kit.
BaseModelRaptor
DFW
I'm running a 17x9 ET18 with 37" Coopers that are slightly larger than a K02. No issues in over 10k miles.
TXRaptor37
georgetown. tx
Found some “R” dealer take offs and installed on stock 35 Raptor. Zero rub and plenty of space which is what I wanted vs needing to level to fit 37s on a wider stance tire/wheel combo.
The +32 offset of the R wheel keeps them right at the fenders. Made a huge difference in the overall look and the ride is amazing.
I put 20” with 00 offset and 37” MTs on my 2022 37PP and though it looked badass, I regretted it after a few months. This is def a better setup IMO, but I see the appeal of the larger rims from pure aesthetics.
GAMike
Georgia
Any feedback on the TIS 556 rims? 17x9 +25 should give the same backspace as stock 37 rims with just a little more poke. I haven’t seen much on them except from a few posts and pictures on line. Any negatives to this brand or rim type I should consider? I’d think I could run any brand 37’s with this offset. Is my thinking correct? I saw another person on here claim they were only 29 lbs after weighing his. Seems like a good weight, price, and versatile backspacing. Makes me wonder why I haven’t seen more in use?
QCRappy
Charlotte, NC
Coming from a 22 35' package I would at least add a SDI top hat and then look into the caster adjustment to bring the tire closer to front fender.
BaseModelRaptor
DFW
I also have a 22 35" and never had an issue with my 37s. Have I full sent it? No ...but it's seen enough travel for me to be confident enough in saying you don't need a spacer lift of any kind if you run an offset close to stock.
I wish people would stop speculating.
