GEN 3 Official Aftermarket Wheels Thread
BIGW0RM
Highest Access Member
Pirate
I just came across this video. This gentlemen has 37" Ko2 tires on method 17x8.5 zero offsets. I was shocked to see that they actually tuck at what looks like full stuff or close to it. Maybe its his 37 pack bump stops keeping it from hitting. I dont know. But I thought zero offset would smack the fenders edge. I was wrong.
FP Forged
Justin
Reno, NV
Technically it’s only the tire height that will cause full compression rub if the wheels are straight. The fronts do camber in a bit but the rears are straight up and down since the rear axle is solid. You start to run into issues if you’re in a drift with the wheels turned on an uneven surface. Then the wider offsets will rub the liner/pinch weld.
mikemcc
harleysville pa
So i read this entire read and i think I’m confused then i was before i started! I’m coming for a lifted f250 to the raptor world. I just got a 2023 35 package. I’m not sure if i want to do a 2” rpg collar. I like the looks of the hostile crandons and 35’s (don’t know what i would need to clear 37’s). I don’t want to lose my ride quality so is it better to stick with a smaller wheel and tire package instead of doing the level and 20’s?
butts182
Jupiter, FL
Yes
So-Cal-Al-52
I Love Fossil Fuel
San Diego
Better to stick to 17 or 18" wheels especially if you are going to run 35's. 20" inch wheels and 35's will ride and perform badly, too little sidewall. I would say 17" inch wheels and 35's or 37's.
