GEN 3 Official Aftermarket Wheels Thread
TXRaptor37
georgetown. tx
Do your tires slip, if/when you launch it at full power?
Also, do you think it's possible to install 13.5 width tire with no rubbing? at +00 offset?
Only had tires for a week but have not experienced them slipping at all and we actually had some heavy rain this weekend and they performed well.
Specs from Yokohama say these are 12.8” wide and I had to trim the carpet liner on the rear liner for front fenders that were rubbing before the 1” Eibach front springs. I don’t think I would try 13.5” wide tires unless you went with even more front lift and/or a less aggressive offset.
Mine are 20x9 +1, but a wheel in the +10 to +20 offset would provide a little better clearance if you felt the need for a wider tire but then you have to consider clearing the UCA with the extra tire width. IMO an aggressive 12.5 looks great and clears well so wouldn’t consider needing wider
Kurator
NYC
Thanks for information, sir!
Do you know if 37x12.5x20 can fit without rubbing at -12 offset?
Is 9 inch rim width is optimal for 12.5 tires?
EndlessEight
Northeast
@Pacific Wheel Will the stock 35" KO2s fit the VenomRex 601BL 17" wheel?
Do you have any recommendations for a similar wheel that has the same look and feel. Just trying to get options since it seems like the 601BL is backordered often. (Probably won't have the truck until the end of the year anyway)
Pacific Wheel
Pacific Wheel
Reno, NV
@EndlessEight The OEM 315's will clear with the 601BL specs. I haven't seen any other wheel companies making anything too similar. We don't sell VR but you might try Nick over at Apollo Optics. He sells a lot of VR wheels.
