91Eunos
Having choices is a good problem to have!
I think the machine shop can probably supply that stuff for you. no need to order yourself unless you have a compelling reasonNeed to finalize that plan and get all the other parts ordered too like the Gen3 crank, ARP studs, etc. too.
After doing this stuff full time for 23 years, its rarely easy and not always fun in the moment. whenever youre feeling overwhelm it's best to take a step back and try to enjoy the journey. And then if you put in perspective the alternatives of 8k for an oem longblock with cast pistons or 14k+ for a brand name motor that doesnt have these features... i think you're doing well. plus you'll have the peace of mind that comes along with doing everything methodically and thoughtfully on your own lift in your home garage. that's pretty incredible in and of itselfStarting to feel like I’m simultaneously getting pulled in all directions, and running around like my hair’s on fire!
So here is another reason not to mess with RMB. Well i pulled the package apart and was going to look at these custom head gaskets with fire rings that RMB sent me. Just to have a look at them and see what would be different from the stock ones. And if you could possible use them.Also i have a set of head gaskets if you need them. They should work for you i think. They are for stock to 95mm bore.
I bought these in hopes that my old block was a head gasket issue. Now they are just sitting on my shelf.
The packages don't look like they were ever opened. But I can just to verify.was machining done to the inner bore of the gasket or something special? Maybe post a photo of the gasket ?
Yes sir! I love this truck! If i had to I would throw an LS in it before I give up on her! Ha!Oem gen 3 gasket. Great head gasket, and it should have been in your engine the entire time, would have been a different animal entirely.
Im sorry you had to go through all that insane levels of frustration. Glad you did not throw in the towel
you spelled "7.3L" funnyI would throw an LS in it
