Gen 2 OE rear shocks on gen 1
Tx State
There are ways to do it. Limiting straps among other things and there will be less if any damage.
Be the test case. Go on a run. Send it. Test it. Prove that there are no issues with it.
Jesus Christ dude I AM NOT SAYING THERE WILL BE NO PROBLEMS I AM JUST TRYING TO ASK QUESTIONS AND GET ANSWERS. i am not trying to prove anyone wrong i am literally just asking for real world experiences.
Tx State
Raptors are already near the limit for cv angle stock. Normal trucks ie f150 are not, so a tophat spacer (which makes the overall length longer) is no big deal. So on a "normal" truck it is a cheap and viable way to raise it. On a raptor, it is already "raised" so if you want to go more then you need to go mid or top perch. Or a front long travel that brings the wheels out wider/higher but keeps a reasonable cv angle.
Thank you thats what i was looking for. That makes sense.
Tx State
Also does a top hat spacer have the same effect as a longer shock does?
Chiefapple
Milwaukee, WI
In this case. Yes it does.
I didn’t realize you wanted a detailed explanation of how geometry changes in suspension when you add a longer piece. Especially when the suspension is already pretty much maxed out.
Chiefapple
Milwaukee, WI
So in all reality, if you knew that adding a spacer that lifted the truck by 1-2” was bad for the geometry because of the INCREASED LENGTH of the suspension, what makes you think that adding 1-2” of height to the truck by adding LONGER suspension was any better?
Chiefapple
Milwaukee, WI
If you think you have to have something installed to understand how suspension works and how geometry works, you’re absolutely wrong.
