Gen 2 Issues/Dislikes
RLTW
TX
Ford must still be using J1 hose clamps. They need to switch that old shit out. Luckily my build isn't for a few weeks...:biggrin:
And yet my truck has never blown a hose and this jen 2 has. Best of luck with your hoses.
Kngranch
El Paso
I took delivery of my truck last Friday, I have around 430 miles on the clock and I absolutely love the truck but I have noticed a few issues:
Steering wheel is misaligned. The truck doesn't pull when you let off the wheel but when I attempt to straighten the steering wheel to its centered position, it makes the truck pull left. (With or without lane assist active)
Drivers mirror vibrates while driving, passenger side mirror is solid as a rock. I've tried folding and unfolding the mirrors as the manual suggested but that still didn't fix the mirror vibrations.
I'm also getting wind noise from the drivers door/window area while driving at highway speeds. I checked the rubber gaskets around the door to make sure they are all seated properly and they look okay to me.
I also have significant surface rust on the rear diff, front cv shafts and other various unprotected steel components under the truck. The only salt/snow this truck could've been exposed to was while it was sitting/being tested in Dearborn. The front cv shafts have so much rust that its actually flinging the rust color onto the front shocks which is very noticeable on blue.
Minor stuff that I will be making you dealer aware of soon.
