So i have the following problem with my 2020 Raptor.
Car drives fine at normal speeds and while towing but when i drive a little higher speeds, above 90mph within a minute the gearbox will give a little stutter and from that moment its all messed up.
Temp will run up and it will randomly go true all the gears on display or looses all the power to the wheels.
Stop the car, turn ignition off and on and car will run oke again and temp will slowly go down again.
Anybody similar problems or know what the problem could be? I’m from the Netherlands so the technical support here is not that wide as in the States.
Thanks for your help!
