G3 Specific Geiser Springs?
sharkhunt
10% stiffer do you guys actually feel it? Can’t decide on Geiser or Eibach
It may be stiffer once compressed, they’re softer at ride height for sure. (Geisers) I like them being progressive, I spend most of my time blasting down the highway or fast dirt roads and it’s night and day. If you’re looking for a spring to always carry heavier weight, these aren’t the ones.
BoostCreep
SoCal
Geisers are night and day softer than stock springs on the road?
sharkhunt
Everywhere at ride height, they’re way progressive. I do have a little extra weight on then, couple hundred pounds max each on the nose and tail, and they’re still softer. If you put a topper on the back or something, they wouldn’t feel softer as they’d be down in the higher spring rate zone of compression.
Another thing I like about them is that they feel like they cycle faster over the small stuff. For me that’s often just imperfections in the road. But yeah, it’s got way more body roll initially until the suspension is set on one side or the other in a turn. It’s a different feel all around. I wouldn’t have it any other way for my use case. (Comfortable and predictable at speed). I feel like they interact well with the ford dynamic shocks.
sixshooter_45
Arnold
Don't forget to recalibrate
Don't forget to recalibrate your live valve shocks using Forscan as it needs to be done.
Lanthas
San Diego
I must have be the one with the opposite feelings of the Geiser springs all around. During my recalibration, I ended up losing the shock modes and steering modes because apparently the ride height of the truck thought it was not level, and had to purchase FDRS access to initialize everything again and get my VDM to not send error codes. I will say I love the rear ones, as I do think they may increase payload a bit since they are slightly stiffer. After my recalibration woes, everything is back to normal more or less, but I do not think they ride softer by any means. They do handle the bumps and any other terrain you would be willing to smack at speed well though.
I think at this point I'm hoping to get some of the new Fox Live Valve Race Series shocks for the G3 whenever they come out.
sharkhunt
Oh man sorry to hear that. I also would love a set of live valves that I could tune “manually.”
McCarthy
Canada
Yikes this is confusing- conflicting reports of whether Geiser springs can handle weight in the box better.
sharkhunt
Yes. They can. But, you’re losing out on the progressive design with them as compared to eibachs.
edit: would still recommend!
KODIAK
I took the plunge, and I'll go out and say they ride better than stock and handle added weight extremely well (ARE cap and decked system). Worth every penny for me...usually I end up holding on to stock parts "just in case" but I chucked the stock springs almost immediately.
