Jonesy_PNW
Did you guys run aftermarket UCAs with the new 3.0 up front? Assuming yes?
I still have stock UCA up front.Did you guys run aftermarket UCAs with the new 3.0 up front? Assuming yes?
I did. Since I did the work myself, and the shocks must come out to replace the UCA I figured it was the right time to do them, whether you want to or not as doing it later requires to remove the shocks again and it is a PITA.
The biggest issue is that if you want to lockout the LCA's, you need UCA's that you can adjust for an alignment.Any issues with running the stock UCAs?
None so far. I don’t have mine preloaded for extra height though.Any issues with running the stock UCAs?
And yes 100% agree the damn struts are a pain to take out lol
I have the Fox 3.0 Live valves with stock backs and my trucks is perfectly fine. I have 3 turns down on the pre load collars and its level and rides perfect.I ran my truck for a couple days with just the fronts waiting on the rears to show up. I didn’t notice any performance issue not running front and rear. It feels much better with front and rear obviously but it functioned fine.
