Front End Suspension Noise
dude1782
PHX, AZ/SLO, CA
Learned about truck suspension in 7th grade home economics?
Sent from my 2017 Raptor using Tapatalk
moreda55
Nor Cal
Had the same thing going on mine as well. The noise started right away after i did the install but everything was tight. It has been about a month and I don't hear it any longer so I think it has gone away.. if it come back I'll probably remove the kit...
MatMan
AridZona
Has anyone tried to spray every joint with PTFE spray (dry film lubricant)? Including any bushings like on the front LCA?
These sat in Dearborne (and operated on snowy salty roads) and we've seen the corrosion photos so could just be a friction issue if it's a creak.
