Friggin Laser Beams (Baja Designs S1 Lasers)
4x4TruckLEDs.com
4x4TruckLEDs.com
Now that I think about it, it was kinda of a stupid question...:banghead:
Do you offer any flush mounted yellow lights I could mount on my bumper?
Thanks...
Yes we do:
S1 Flush Mount Spots: http://www.4x4truckleds.com/baja-designs-s1-led-flush-mount-spot/
We can swap out the spot lenses for you and put in Wide Cornering, Amber for you (as we stock all the S1 lenses as well)
S2 Sport, Flush Mount: http://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/s2-sport/
S2 Pro, Flush Mount: http://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/s2-pro/
Squadron Sport, Flush Mount: http://www.4x4truckleds.com/led-driving-fog-lights/baja-designs/squadron-sport/
Squadron Pro, Flush Mount: http://www.4x4truckleds.com/led-driving-fog-lights/baja-designs/squadron-pro/
4x4TruckLEDs.com
4x4TruckLEDs.com
Im ready to throw some money, is there a frf discount code?
Check your PM's for pricing. Our discount code (RAPTORFORUM) does not work on all items in our store. But we can talk pricing one-on-one
RotorHead695
Molalla, OR
Do you have a reverse kit for S1 flushmount, work/scene lens, wiring harness that allows for automatic in reverse in addition to the upfitter switch?
Your website showed a picture of the work/scene lens, but title text says wide corning. Also doesn't explain if it has wiring harnesses for both upfitter and auto reverse.
4x4TruckLEDs.com
4x4TruckLEDs.com
Yes we do. We offer an all-in-one upfitter harness. It includes the wire connectors for your upfitters and then all the way to the rear tails it's one solid harness with the built in connections for your S1/S2 lights and a spot to plug in the rear upfitter harness (if you want to use it, you don't have to but it's in the kit). REALLY nice and prevents your factory reverse lights from turning on when you activate the lights from your upfitter (which is REALLY good for when you want to use the reverse lights on a trail and throw amber covers over them for chase lights, although with flush mount, no covers).
We stock all of the S1 components so we can change the parts of the kit for you at no additional cost. So you'll want the following
2x Flush Mount Work/Scene: http://www.4x4truckleds.com/baja-designs-s1-led-flush-mount-work-scene/
1x CrystaLux Upfitter Connection Harness: http://www.4x4truckleds.com/crystal...ness-for-2017-ford-raptor-s1-s2-reverse-kits/
1x Upfitter Harness: http://www.4x4truckleds.com/baja-designs-ford-upfitter-wiring-harness-squadron-pro-sport-s2/
Now that last upfitter harness is optional and only necessary IF you want the lights to come on automatically when you go into reverse.
richnot
Central New Jersey
Zombie Killer, I almost have the wife buying a set for the truck. Main selling point was that she would be able to see the store hours from far away, saving valuable shopping time
