Frame swap please help
K
Kevinz3451
Have you talked to a frame shop about this? Its very likely that it will be more economical for you to take it in and have it straightened/patched than doing an entire frame swap yourself. Unless the frame is really pretzeled. Got pics?
II Sevv
Arizona
It’s probably far cheaper just to pay someone who does fabrication work to cut out the messed up sections of frame and re-plate it. The guy that does the custom work on my truck charges like $70 an hour to do side work. That’s way cheaper than buying an entirely new frame and swapping stuff over.
K
Kevinz3451
Where are you located and do you think he can fix the damage on my truck
Canuck714
San Antonio TX
Have you taken it to a good shop and put it on a frame rack to see if it can get pulled and plated? That looks repairable to me.
Also, Ford sells replacement frame sections for these truck. You basically have to remove everything attached to the front of the truck to do it, so the labor cost would likely be the limiting factor.
Are you trying to do this yourself?
