Frame is fine. I have RPG bumps and frame reinforcements and some of my own custom add ons.
I remember when this happened now and it's been a couple of months since the driver side probably broke and the passenger side broke last week.
I was a chase truck for several of my friends on dirt bikes going from Wickenburg, AZ to the Colorado River via Lake Alamo. The road is a blast on MC's and also in the truck. There is a section about 10 miles long that is straight with large berms about every 1/2 to 1 mile apart. It's definitely a 100 + mph road. Going down I was hitting between 100 and 115 by GPS. all the jumps were perfect launch and land flat on all fours accept for one that was the largest one. I did land on right front first but it was not a big hit as far as I was concerned. definitely nothing to pull over for. The same type of thing happened when the driver side broke and I got pretty good air on that one so I'm pretty sure that is when the damage was done and I just never felt it in the handling or anything else. Madcow can probably attest that he didn't feel anything odd after he discovered his were broken either.
---------- Post added at 08:40 PM ---------- Previous post was at 08:31 PM ----------
I spoke with Corey last night regarding my shocks. From what I could tell they did not show any damage and the ride had been good. Turns out that finally having something first generation doesn't have an issue. The top of the shock design is different between the first gen and the second gen. There have been no failure with the first generation shock mount. I'm not sure when they changed the design to the current mounting configuration.
Yukon Joe
GREAT LAKES RAPTOR EXCURSIONS
I'm a little confused. Corey told me that the first gen shocks had the aluminum ones and that they were having problems like this so they switched to Chrome Moly.
What I read you to say is that the 1st gen didn't have any problems and that they changed design between the 1st and 2nd Gen. All I know is that the new top mounts for the shock is Chrome Moly and I don't' consider that a design change but a material change to fix a problem with breakage.
