Fox 3.0 Shock Settings & Maintenance
Huck
Chicago Sw Burbs
i have rpg rear fox 3.0 shocks, i have tried most of the settings on this thread. my truck currently is 4 turns from closed on compression and 3 from closed on rebound. my truck makes small bumps feel very very rough, and i have significant wheel hop on hard acceleration. any one have a suggestion for tuning them? I am assuming the setting suggestions on this thread are for stock springs. I have deaver +2s.
Try opening up the compression tubes. Mine are at 7 turns from closed and it's pretty smooth.
Keep in mind with the larger amount of dampening you'll feel more "small" bumps and road heaves
hackleman
Odessa, TX
what is your rebound set at?
Huck
Chicago Sw Burbs
I want to say 5.5-6
Anything less and Gravity was beating the rebound.,
Rear ended was hanging and whole truck was dropping faster then the axel
ckanderson
Nashville TN
When we set out to develop the Fox 3.0 SVT Raptor system we never forgot that 90% of the time the truck is used as a daily driver. Out of all the 3.0" systems on the market, we use the softest spring rate. By utilizing a soft spring, we are able take full advantage of the Internal By-Pass system and tune the effective ride zone to be very plush and comfortable for daily driving and wash board type of roads, yet still have the power required to handle the full compression and rebound zones. I think the best way to describe the on-road mannerism of the shock is confident and composed. Harshness over small pot holes and speed bumps go away and the overall feel is very confidence inspiring.
Hope this helps give you a better understanding.
Thanks
Fox
Is there different valving available from you guys when the shocks are bought new? Recently bought a used 2010 with your 3.0's on there, installed about a year and a half ago. Truck is exceedingly stiff on any pothole/or sewer grate style bump, but rides very well at freeway speeds (with smooth surfaces).
Just wondering if the previous owner possibly requested special valving.
Thanks
nbg-mustang
Thanks
Fox
Not mine one! Front are the same like stock (harsh) and on the rear same problem (Fox 3.0 and Deaver +3)
What setting do I need?
I all the time try new and new setting, but..... nothing.
Can you help me?
Daniel
ckanderson
Nashville TN
Thanks
To close this out, my tires (general grabbers) caused the rough ride. When I switched to BFG KO2's the ride improved 100%
2tqdtm
Russia, Samara
Hi,
I bought Fox 3.0 with a small mileage at the seller's request,
when I received it - I saw that the stock from one does not come out completely,
but it can be pulled out by hand, the stocks are pushed in with considerable but equal effort.
The nitrogen pressure is the same, what could be the reason?
Yukon Joe
Yukon Joe
Trafford, PA
Hi,
Low fluid? Or internal valve stuck?
@RPG would know.
Regardless, you'll probably need to rebuild the one shock.
@Yukon Joe :baby: :baby: :baby:
Drive your raptor here!!!!
www.runraptorrun.com
( * Y * )
RPG
Orange County
There could be a lot of different things. Can you ship us the shock?
