oplersx
Got the tracking number, FOX 3.0 is on the way, should arrive early next week. Preparing myself for install so looking for tips/tricks, especially height pre-set. Thanks!
They should come pre set to level ride height. Expect them to settle about 1/4 inch after some driving. Not a whole lot to the install. Lot of people loosen the axle nut, but I never do. But do make sure you disconnect the sway bar to get more droop. There are a ton of YouTube videos on it. I like this one
Sent from my SM-G975U using Tapatalk
You can only adjust the height once installed. There is a spanner wrench that you need and its actually way easier to do when the shocks are already mounted. If you are going to adjust them, do it the first time u install them because any significant height change will require another alignment.
