- Joined
- Dec 16, 2016
- Posts
- 17,708
- Reaction score
- 27,334
I freakin’ hated when the chisel kept getting dull.Stone tablets.
Ok I will start nerding out…looking no, but I do check psi monthly unless I off road then it’s before and after. Also, if road noise is different and if the handling is “spungy” then I do a tire check. No ng for me, airing up and down would be too$$$So you can look at a Raptor tire and tell me that it is low by 10lbs? You test your tires EVERY TIME you get in your truck and verify your tires are 100% perfect before you drive. Let me guess, you run nitrogen fill and can tell when the tire is off .5lbs...... Keep fooling yourself. I had a screw in my tire, inside the tread and it was on the inner block on the rear tire on the drivers side. Started the truck and showed 20lbs instead of 38. I got out and it was almost impossible to even see that the tire was low. I am very conscious of tire pressures due to track time I have put on the M3 so it is not like I am some uneducated lazy person who knows nothing about cars...
