this is super helpful! I like it in this format...definitely a spreadsheet guy lol. I like that it has each module and brief description of what exactly I am changing.
This looks to be from a Gen2, do you know if there is an update for Gen3s? I was going through the same route in Gen3 Forscan but I think it is different. It looks like this option could be farther down coding for Gen3s, but didn't want to go exploring with it if I was wrong.Hey man. Found this in the fourm. Save you some time searching or waiting for an answer.
Can’t comment on the second option as I use the usb cable, but why spend an extra 80 bucks for the same results?So this adapter plus Windows laptop:
OBDLink EX
When looking for a top-of-the-line OBD II adapter that works with FORScan, look no further. At OBDLink® we have the right scan tools. Purchase here!www.obdlink.com
Is better for adjusting ForScan settings over this adapter and Android phone:
OBDLink MX+
The OBDLink® MX+ is the top-of-the-line OBD II scan tool to use with forscan and comes with bluetooth. Get one here today and gain access to your vehicle!www.obdlink.com
Sorry didn’t notice that. Try this oneThis looks to be from a Gen2, do you know if there is an update for Gen3s? I was going through the same route in Gen3 Forscan but I think it is different. It looks like this option could be farther down coding for Gen3s, but didn't want to go exploring with it if I was wrong.
FORScan Tutorial
Updated 2/10/25 - Livnitup What is FORScan? FORScan is software used in conjunction with a specific type of OBDII adapter that enables you to make changes to your truck's default modules' settings. Some popular things that can be changed are: adding heated and/or cooled seat icons & heated stee...docs.google.com
ACM | 727-01-01 | xxx8 | xxxx | xxxx |
ACM | 727-01-02 | 0A88 | C3xx | xxxx |
Do you have a Gen 3 or Gen 2?I dipped my toe into the ForScan pond today and after saving the as-builts for every module, I started working through the typical changes (double honk, bambi mode, brighter DRLs, markers on w DRLs, numerical gauges, belt chimes, Unreal theme, glare free lights, etc).
I also tried the audio system mod from post #9 of this thread - and the difference is substantial. Really transforms the stock B&O system.
Here's the changes I made (in the file attached to post #9):
ACM 727-01-01 xxx8 xxxx xxxx ACM 727-01-02 0A88 C3xx xxxx
Going to do the "camera on w fwd sensors" mod tomorrow. I didn't have it copied down right when I was in the truck with the laptop this afternoon.
Gen 3 - production date of 12/13/22.Do you have a Gen 3 or Gen 2?
