Livnitup
SoCal
If I want to have Park lights and Halo DRL lights to come on when truck is running what exact changes do I need to make out of the ones listed in spreadsheet?
Feature Name Module Address Value change
DRL - Parking Lights only (stock LEDs only)
BCM 726-26-02 x1xx xxxx xxxx
726-50-01 01xx
and do I also do this for Halos below or will the upper one do both?
DRL - Turns only (Halogen/aftermarket lights only) BCM 726-45-01 xxxx 7Fxx xxxx
726-50-01 08xx
726-50-01 08xx
* Make the changes at 726-45-01 & 726-26-02 above first before doing the 726-50-01 change.
---------- Post added at 01:11 PM ---------- Previous post was at 01:10 PM ----------
If anyone here with an 801 package is interested in upgrading to the 8" cluster, pm me.
mmacfn
Show low, AZ
@LIVinitup
Is this just purely aesthetic and are their risks of damaging the lights over time being on constantly?
726-50-01 08xx
Livnitup
SoCal
@LIVinitup
Well there have been some guys on the F150forum who are skeptical that the turns were designed with a duty cycle to be able to be on constantly as DRLs but there hasn't been any evidence presented either way. With that said...I'm not doing turns as DRLs in my own truck Lol.
mmacfn
Show low, AZ
Thats all i needed to hear!
Thanks for all you do it is REALLY appreciated!
What have you done to your own truck?
Livnitup
SoCal
IPC: Added Avg Speed Menu item, Disabled Door Ajar warning chime, enabled tire placard "Specified" tire pressure display, enabled temps above eng/trans gauge, disabled Driver Seatbelt Minder
BCM: enabled DRL-Parking Lights Only, enabled "Bambi" mod (ability to do fogs & high beams at same time), disabled double horn honk, enabled global window open/close, enabled auto re-lock, enabled secure idle, disabled powerpoint timeout, changed panic button on fob to require 2 presses, enabled parking lights when remote started
DDM/PDM: enabled global window open/close, Lincoln style autofold mirrors
SCCM: enabled 5 flashes on turn signals
APIM: Stereo extended play time to 60 mins, enabled heated/cooled seat buttons & HSW button to home & climate screens, enabled Ford GT blue theme, enabled NAV in motion
ABS: enabled Hill Descent Control w/switch
PAM/APIM: enabled Perpendicular AutoPark
and probably 5-10 more that I'm forgetting off the top of my head
copb8
Highland Village (Dallas) TX
Ok, I've been at this all day and finally have forscan registration approval. I've read the entire tutorial (I think) and searched for over an hour for this problem.
When connected to the truck I don't see ACM module to turn off engine noise or DDM Module. I only see APIM, DCDC, PAM and BdyCM.
I have the recommended wired OBDII module in the HS position.
Scratch this request. I finally worked out you had to cycle the MS/HS switch while in the Forscan application. Duh!
Viper32
726-50-01 08xx
I got it thanks for the help.
---------- Post added at 05:51 AM ---------- Previous post was at 05:49 AM ----------
IPC: PAM/APIM: enabled Perpendicular AutoPark
Will this work on the Raptor with 802A / Tec packages? If so what do I need to do?
95,793
59,476
egermann
